March 26, 2021 at 4:25 pm
MANNAN
Subscriberx=linspace(-d/2,d/2,N); # x position vectornnfor (i=1:N) {nadddipole;nset(x,x(i)); nset(y,0);nset(z,0);n}nThis code will make a line of N dipoles along the x-axis between length -d till d.nnSuggestions required in making a script that will make a cone of dipole along xz direction with radius r in x-direction and depth along z-axis nnLooking forward to hearing soo nn -
March 29, 2021 at 1:13 pm
Karthik R
AdministratorHello,nWhich product are you using?nKarthikn -
March 30, 2021 at 5:47 am
MANNAN
SubscriberI am using FTDTn -
March 30, 2021 at 12:38 pm
Karthik R
AdministratorHi, nAre you using Ansys Lumerical (by any chance) in your analysis? Can you post some screenshots of the tool here?nThank you!nKarthikn -
April 1, 2021 at 5:38 am
MANNAN
SubscriberHello, nYes I am using Ansys LumericalnRegardsnMannann -
April 2, 2021 at 4:27 pm
Karthik R
AdministratorHello,nThank you for confirming. I've moved this question to the Photonics category. Someone should help you out soon.nKarthikn
Viewing 5 reply threads
Trending discussions
- Error on Lumerical device
Top Contributors
2524
2066
1279
1096
459
Top Rated Tags
