standard initialization in the case of two inlets (Fluent)
    • manelaero2020
      Hi everyone;
      I'm simulating a flow with two inlets. Is standard initialization possible in that case?
      Thank you very much
    • Swathi V. V.
      Hello Yes, you can use standard initialization. You can compute the values from information in a specified zone or enter them manually depending on the initial state of your case.
      Please refer to 32.9. Initializing the Solution (ansys.com) and 32.9.1. Initializing the Entire Flow Field Using Standard Initialization (ansys.com)
    • manelaero2020
      Ok thank you
    • DrAmine
Viewing 3 reply threads
