Preprocessing
Preprocessing
Starting meshing in student ANSYS 2019 R2
    • b6008632
      I have downloaded 2019 R2 student version and need to begin meshing. How do I begin this to create a watertight geometry meshing loading my .geom file.
      You want to connect Geometry to Fluent with Fluent Meshing.  If you're using SpaceClaim you don't need Workbench and can use the buttons under the Workbench tab.
    • Keyur Kanade
      What is .geom format?
      Do you want to use watertight geometry meshing in Fluent Meshing?
      you can also check ansys meshing.
      Keyur
