state-space matrices with piezo sensor
    • Md_Salem
      hello,
      I am using 'SPMWRITE' with coupled field structural system, where Piezo-sensor is used.
      In order to construct output array using :
      *DIM,OUTPUT,,1,2
      Is it possible to define the output of the system as the output voltage of the piezo sensor ? and if so I need to define OUTPUT(1,2) which supose to be voltage/charge on the surface of the sensor, I know that Ux=1,Uy=2, Uz=3 ,ROTx=4, ROTy=5, ROTz=6. So, how to assign the volt/charge of piezo sensor to be the output? i.e OUTPUT(1,2) = ???
      Regards
    • Ashish Khemka
      Hi @Md_Salem,
      Please see if the following link helps you:
      2.5. Piezoresistive Analysis (ansys.com)
      Ashish Khemka
      • Md_Salem
        Hello Ashish ,
        appreciate for your help , but unfortunately this topic disscusses the piezoresistivety, my actuators/ sensors are piezoelectric. The main point for me -which I need help with- is how to get state-space matrices for such system.
        Regards
