Static Analysis Of soil and pile
    • Ankitha
      When I try to do the analysis of a single pile in a sand layer, it says that my sand has not been defined with right properties. Can I get some help regarding that?
    • Keyur Kanade
      As ANSYS Staff, we can not download attachments. Please insert images using insert image functionality.
    • Ankitha
      Thanks for the reply. I could run the analysis after setting sand properties required. But I see some errors which I am attaching here.  Also, should i manually define contact regions for sand and pile? If yes, which will be the target body?
