September 18, 2023 at 7:19 pm
Bilal Akdağ
SubscriberHello, My license is 2023 R2 educational. I have a problem with importing body in static structural section. Im a solidworks user on CAD side, Just created a bridge made of lines, exported it as step file and tried to import into geometry.
this is the response I get
And this is the line body I wanted to import
This is the response I get when I create same sketch with design modeler:
Please help.
September 18, 2023 at 8:08 pm
Ankush Choudhary
SubscriberHi Bilal,
Please check out the below post.
https://forum.ansys.com/forums/topic/how-to-use-line-bodies-in-2d-structural-analysis/
September 18, 2023 at 8:33 pm
Bilal Akdağ
SubscriberI am not sure if my problem is related to that. My problem can be simplified as 2D.
September 19, 2023 at 6:22 am
Erik Kostson
Ansys EmployeeHi
As mentioned in properties (Analysis Type) you need to set it to 3D as beam/lines will not work with 2D option.
To have 2D in the 3D analysis then just fix the Z - direction on all nodes and the ROTX and ROTY.
Set a snippet with:
D,ALL,UZ,0
D,ALL,ROTX,0
D,ALL,ROTY,0
That makes it 2D in principle
September 21, 2023 at 9:01 pm
Bilal Akdağ
SubscriberTried it in 3D too. Still did not work. I found the reason. There was no cross section dimensions. So when I attached a cross section dimension to sketch by design modeler, it worked. But I need something faster. A step file to be imported in sketch so I can define a cross section dimensions in the inside of ansys.
4502
2963
1449
1322
