Static Structural analysis of I-beam
    • muzammilmustafa
      I am biginner to ansys , using ansys 14.5 due to limited system specs , , I am doing static structural analysis of an I beam . . whose lower face of base plate is fix ,, and a moment about x axis is applied , , base has gussets welded to base plate and I beam , , ,I beam is also welded with base plate (fillet weld , , used solidworks as CAD tool) please review this meshing and results are ok?? (Zoom in to see mesh clearly)
    • Dave Looman
      Mesh looks excellent and results look reasonable.n
    • muzammilmustafa
      thank you so much sir . . .can you please tell me what this crossed tick indicates in my geometry tree . . . . the geometry has only tick but the parts in that geometry as shown have this crossed tick . . . nn
