Static Structural Problem
    • NicoReve
      Hello everyone,
      once I've made my 3D part in PTC Creo and saved it as .stp (step) my ansys workbench solutions doesn't appear. In particular when i press 'solve' button in addition to the workbench windows a 'Distriubuted Mechanical  APDL Batch running with 2 cores requested' opens and after a couple of minute even a simple analisys crash. Where is the problem? How can I fix it?
      Thank you for your help.
    • Aniket
      Can you please explain your workflow with some images? If you are seeing 'Distriubuted Mechanical  APDL Batch running with 2 cores requested' , means you are past import mesh and setup.
      Which version are you using? also which license?
      -Aniket
