March 21, 2021 at 4:11 pm
F029953h
SubscriberI recently attempted a static structural simulation on a model I produced on Ansys, the simulation worked correctly the first two times around displaying the von Mises stress profile however the third time around it gave me this error nThe result file C:\Users\lukef\AppData\Local\Temp\WB_lukef_11148_2\wbnew_files\dp0\SYS\MECH\file.rst cannot be opened. nAnd Current result file may not contain requested result data C:\Users\lukef\AppData\Local\Temp\WB_lukef_11148_2\wbnew_files\dp0\SYS\MECH\file.rst. Please clear the solution and solve again.nI attempted resetting the solution and attempting to solve it again however It produced the same error, I tried creating a new model with new data from scratch however got the same error.nI am unsure as to what caused this issue as the only thing which was changed for the third test was two stress values.nAny solutions or suggestions around this issue would be greatly appreicated.nn -
March 22, 2021 at 11:31 am
ANSYS_MMadore
Ansys EmployeeCould you please share a screenshot of the Tools -> Options -> Project Management from within Workbench?n -
March 22, 2021 at 11:36 am
March 22, 2021 at 11:52 am
ANSYS_MMadore
Ansys EmployeeArray Could you try changing Default Folder for Temporary Files to something like C:\Temp\Ansys and make sure that directory exists, creating it if needed?. -
March 22, 2021 at 12:23 pm
F029953h
SubscriberArray That directory did exist and I changed the path to that however I ran the simulation again a few times and it produces the same result as before while giving the same error.nMarch 22, 2021 at 12:33 pmF029953h
SubscriberMoving the files from the one drive folder also seemingly didn't affect it in any way.nnApril 1, 2021 at 8:15 pmANSYS_MMadore
Ansys EmployeeCan you share the full contents of the solve.out file?nViewing 6 reply threads- You must be logged in to reply to this topic.
Trending discussions
- Workbench error
- Workbench not opening
- License Error
Top Contributors
2656
2120
1347
1118
461
Top Rated Tags
