April 4, 2023 at 8:05 pm
Mahmoud_87
SubscriberHow to apply static structure after ls dyna analysis for collisioned model?
April 4, 2023 at 8:52 pm
Andreas Koutras
Ansys EmployeeHello, do you mean how to perform a static analysis after an explicit analysis?
To switch from explicit to implicit, the option IMFLAG<0 of CONTROL_IMPLICIT_GENERAL can be used. However, it may be challenging for the implicit analysis to converge depending on the level of prior damage and various analysis settings. Applying the load quasi-statically using explicit analysis will be more promising
April 4, 2023 at 8:56 pm
Mahmoud_87
SubscriberHello, thanks for ur replay. Unfortunately, I don't get the point, can you give more explanation?
April 5, 2023 at 10:21 am
SubscriberHello Mahmoud,
Andreas is suggesting to apply the static loads in the LS-Dyna solver at the end of the collision event and not use the Static Structural solver.
Please explain what type of static load you want to apply to the model after a collision event. Show an image if possible.
- explicit dynamics
- Explicit dynamics ERRORS
- turning simulation
- Monte Carlo Simulation
5290
3311
2471
