March 1, 2022 at 8:59 pm
gyoussef
SubscriberIn this analysis, I'm doing a simple compression of a polymer plug between a compression platens. I used to run the analysis in 18 and it worked very well. For some unknown reason, I'm following the same steps but not getting convergence nor solution. Any suggestions? Please see attached.
March 2, 2022 at 1:32 pmMarch 9, 2022 at 9:15 pmgyoussef
SubscriberDear Ashish Thank you for your response. Do you detect anything wrong with the previously attached simulation?
I don't have access to 18 anymore but here the 21 file.
Thank you
2524
2066
1279
1096
459
