Status of solution when we change network
    • Samir Kadam
      Will the current running solution for Mechanical stop when I move from office to home and change network?n
    • Aniket
      If you are using standalone license then you can change the network,nIn case license is drawn via the network then changing the network may result in error like License Server lost.n-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumnn
