August 29, 2019 at 3:42 am
Tristan
SubscriberHi,
I am using ANSYS 2019 R2 student edition and I am trying to do a steady state heat transfer on a 2d rectangular plate. I have created the surface in spaceclaim but when I try open model it says:
Update failed for the Model component in Steady-State Thermal. Unable to attach to geometry file C:UsersTristanDocumentsUniversity stuffVIPANSYS stuffPracticeGeometry 2D plate_filesdp0SYSDMSYS.scdoc. Unable to attach geometry.
I have made sure the geometry is a surface before opening model but the error persists.
Please can someone help in this regard.
Thank you.
August 30, 2019 at 9:56 am
Ansys EmployeeI don't use Mechanical, but are there any limitations regarding which plane the 2d part is in? Ie must it be on the z=0 plane?
August 30, 2019 at 10:00 am
Subscriber2D geometry must be on the XY plane. Axisymmetric Mechanical models must have the axis on the Y-axis (unlike Fluent which uses the X-axis).
August 30, 2019 at 12:43 pm
Ansys EmployeeThanks Peter; it figures that Mech would use a different axis.....
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
2522
2064
1279
1094
456
