3D Design
3D Design
Steady State Thermal – Contact Settings
    • hani.sadek_i
      Is there a way to automatically define contact between faces in steady-state thermal?
    • 1shan
      Contacts will be automatically generated between parts after geometry import. You could also RMB>contacts>create automatic connections to generate contact automatically and also set the required auto detection tolerance setting. Another option is using the select by>size>all entities with the same size, which allows you to select large number of geometrically similar faces and define them as contact and target.
      Regards Ishan.
    • hani.sadek_i
      Thank you !
