June 16, 2023 at 10:15 am
shubhamop20
SubscriberI am performing a 2d axisymmetric steady-state conduction simulation in ansys workbench. Now I want the radial temperature data at various heights as providing those paths manually is tedious. Can I write a user-defined result for this or any other method ?? my model is a square of size 3.025 mm and in the first quadrant(a requirement for 2D simulations). So let's say I want radial temperature at various y coordinates(height) in increments of 0.1 mm.Please, if possible help me with the Apdl command so that I can write those in the solution section and get the temperature data or you have any other method, it will be helpful. Currently, I am manually making paths using construction geometry and getting the results.My ansys version is 2015. -
June 19, 2023 at 1:07 pm
Ashish Kumar
Forum ModeratorHi Shubham,
One approach is to have a mesh of 0.1mm and then export the temperature data with nodal locations.
Ashish Khemka
4468
2955
1427
1322
