March 11, 2021 at 2:19 pm
Abubakar
SubscriberCan anyone please tell me the basic difference between steady state simulation, pseudo transient simulation and transient simulation? nI know how steady and transient simulation works but I don't how this pseudo transient simulation works and also under what condition we should choose pseudo transient simulation? TIAnnThank you,nAbubakar khan n -
March 11, 2021 at 3:14 pm
Karthik R
AdministratorHello,nPseudo transient is an implicit under-relaxation method where the time-step is used to under-relax the solution. This is used only for steady-state simulations for the pressure-based coupled solver. nTo understand this better, I recommend that you look into the following links from the Fluent Theory Guide.nI hope this answers your question.nKarthik -
March 11, 2021 at 4:36 pm
Abubakar
SubscriberSir, I will go through the Fluent Theory Guide to understand Pseudo transient better, but my question is why do I need to run Pseudo transient simulation why can't I settle with Steady state or transient state? Can you give some examples where I have to run Pseudo transient simulation.n -
March 11, 2021 at 5:48 pm
Ansys EmployeeRead the solver section: that'll explain what the pseudo transient setting means in the solver. Note, this is distinct from steady cases which show some transients in the results which are also referred to as pseudo-transient: someone decided to re-use the term..... n -
March 15, 2021 at 3:31 pm
March 15, 2021 at 5:28 pm
Ansys EmployeeThat's all we can share due to the export rules we work to. Default time scale factor is 1, I find 0.1 to be stable for most applications I work with. n -
March 15, 2021 at 7:16 pm
DrAmine
Ansys EmployeePlease check open literature to learn about time marching methods for solving steady state Equations.n -
March 26, 2021 at 3:52 pm
Abubakar
SubscriberAny reference on the above? TIAn -
March 26, 2021 at 4:37 pm
Ansys EmployeeI found several possibles using that largely neglected tool called Google. Otherwise read the Theory Guide and there may be references there, typically [123] as links to the reference section. n -
March 26, 2021 at 4:40 pm
DrAmine
Ansys EmployeeGoogle is a good tool.n -
March 26, 2021 at 4:43 pm
Abubakar
SubscriberThanks sir & sirn
Viewing 10 reply threads
Trending discussions
Top Contributors
2524
2066
1279
1096
457
Top Rated Tags
