January 31, 2021 at 10:29 am
Draxler
SubscriberHello,
I am doing a Heat-Exchanger simulation using Ansys Fluent.
This is the result when I simulate: "Steady"
February 1, 2021 at 3:45 pmRob
Ansys EmployeeWhat was the initial condition you set?nFebruary 1, 2021 at 3:49 pmDraxler
SubscriberWhat was the initial condition you set?https://forum.ansys.com/discussion/comment/105155#Comment_105155
Do you mean the boundary conditions?nInlet: 2m/s at 300KnHeating Elements: 500KP.S I thought I made a mistake yesterday so I tried re-posting the same question just now. Please delete the duplicate post if you can. ThanksnFebruary 1, 2021 at 4:06 pmRob
Ansys EmployeeNo, when you initialise a model you put in certain values. In steady those will very quickly be changed to the solved flow field, in transient that takes time so I want to know what the initial temperature field looks like (ie at t=0s). nFebruary 1, 2021 at 5:10 pmDraxler
SubscriberSince I don't fully understand that, I'm guessing that might be the problem.nnWhere can I change/edit that?nThis is currently how I am initializing. (I've also tried using Compute from All-zones and still the same results)nnFebruary 1, 2021 at 5:12 pmRob
Ansys EmployeeIf you're using standard initialisation you'll have options to set all field variables in the panel. These need to represent the time zero situation. The transient solver will then solve the changes from that position with time. nViewing 5 reply threads- You must be logged in to reply to this topic.
5290
3311
2471
