Photonics
Photonics
Step 4 in SWFM Microring Resonator photon source
    • Jong Ryul Kim
      I was following the example "Spontaneous four-wave mixing (SFWM) microring resonator photon source". In step 4, I had an error in the script line 17 as shown below screenshot. I am not sure how to fix the problem.
    • Guilin Sun
      Thank you to bring this issue to us. The "mode_area_SiN_updated" file is missing. Once found we will update the website.
    • Guilin Sun
      I believe the website has been updated and file name also changed. Please check and see if it works.
    • Yang Yongxiang
      I also encountered this problem. I just downloaded a new file, but I found that the script has not been modified. This issue still occurs after running.
    • Guilin Sun
      Thank you for pointing out. Please do the following modification:
      1: rename file effective_mode_area.lsf to be effective_mode_area_function.lsf;
      2: open mode_area_step4.lsf ;
      2: modify the function name from " mode_area_SiN_updated" to effective_mode_area_function. eg
      #mode_area_SiN_updated;
      effective_mode_area_function;
Viewing 4 reply threads
