June 30, 2020 at 2:24 pm
cansin123
SubscriberI'm having a issue importing a inventor and .STEP file
This is the error I get once I import the model.
ERROR:
pIPartMgr->AttachAssembly() failed!
Current Coordinate system is global
June 30, 2020 at 7:03 pm
Karthik R
AdministratorHow are you attaching your geometry? Design modeler? Have you also tried to import using SpaceClaim? If you haven't done it yet, please try it out and let me know.
Thank you.
Karthik
July 1, 2020 at 5:57 am
Keyur Kanade
Ansys Employeeplease use latest 2020R1 SpaceClaim.
Also please check if you can use iges or parasolid format from inventor.
Keyur
- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
3670
2548
1749
1226
582
