Discovery Import
Discovery Import
Step File Storage
    • 3Dmodel
      Is there a way to store tools from from AndyMark, Rev Robotics, e.c.t? If I were do download a bunch of .step files like the ones above, how do I get them into Discovery to then be able to use during the building stages?
    • Subashni Ravichandran
      Hello Sophia Bleymaier
      I'm not quite sure how this can be done. I will need to check this.
      I will keep you posted on this one.
        Sophia Bleymaier
        I think I got a little confused by your query.
        If you are taking about importing a Step file, that can be done in Discovery by just toggling the file format and setting the appropriate one during importing a new file.
        If you want to open the Step file as a script, you can as well do that by launching the script editor and use the File Open option and setting the appropriate file type.
        Let me know if you face an issue with that.
      Sophia Bleymaier
      This is currently not possible in Discovery
