March 24, 2022 at 2:07 pm
Mert41
SubscriberDear Experts;
I am trying to make a transient thermal anaysis to obtain residual stress due to welding process.
I will make number of steps and i will apply different tempratures to every section in order to create welding speed.
But I cannot change step end time it stays always 1s. Is it possible to apply different step end time for the steps?
thanks for your suggestions.
March 25, 2022 at 2:12 amMarch 25, 2022 at 5:11 amMarch 25, 2022 at 10:22 ampeteroznewman
SubscriberYou can't use 10 s for the end time of step 1 if the end time for step 2 is <10 s.
Change the Current Step Number to 2, then make the end time for step 2 >10 s.
Then change the Current Step Number of 1 and make the end time 10 s.
March 25, 2022 at 11:01 amMert41
SubscriberYes it worked. Thank you for your support and advice.
in this situation the next step number should have bigger step end time tha previous one.
Best regards.
Viewing 4 reply threads- You must be logged in to reply to this topic.
Trending discussions- Solver Pivot Warning in Beam Element Model
7742
4502
2961
1449
1322
