Preprocessing
Preprocessing
Topics relate to geometry, meshing, and CAD
Stiffness bevaiour to rigid as default instead of flexible when updating a model.
    • muhammad
      Hello everyone,
      I would like to ask, if there is any possibility to fix the behaviour of the body as rigid instead of flexible. Actually i am doing a parametric study using spaceclaim scripting. Scriting in spaceclaim always change the model when run several time for different design points. At each design point scripting updates the model in mechanical because of which model material properties set to default again which is flexible. So after 1st simulation it does not solve further.
    • Aniket
      I believe there is no direct way to change it as of now, but you should be able to use ACT script something on the lines:nbody_1.StiffnessBehavior = StiffnessBehavior.Rigidnin Mechanical to automate this in Mechanical. If you want to automate it at workbench level you can also do that by sending mechanical script from workbenchnPlease check this post for that:nRun Mechanical Macro from Workbench ? Ansys Learning Forumn-AniketnHow to access Ansys help linksnGuidelines for Posting on Ansys Learning Forumn
