August 6, 2019 at 9:56 am
Winzozz
SubscriberHi all!
I'm an aerospace engineering student from Italy, I'm preparing my thesis with ANSYS and I've got some problems: the objective is obtain the stiffness matrix of my composite plate, but ANSYS seems like to always reject my request with this error:
*SMA Command : Fails to open the file file.full.
That's the code I used:
! Gets Stiffness Matrix
*SMAT, MatK, D, import, full, file.full, stiff
*SMAT, Nod2Bcs, D, import, full, file.full,NOD2BCS
*print, MatK, matk.txt ! Exports Stiffness Matrix to Text File
*export, MatK, mmf, matkMMF.txt ! Exports Stiffness Matrix as MMF format
I'm also attaching my project if you want to know more about it. I use ANSYS 19.2.
Best regards,
MN
August 15, 2019 at 8:19 am
BenjaminStarling
SubscriberWhere and when are you using that script? I have downloaded the project and can't find the script in the mechanical application. I also could not find the FULL file in your solver directory. Have a look at the WRFULL command to force get your full file.
The script you have, at first glance, should work.
2156
1359
1150
462
