August 26, 2018 at 9:53 am
engmost
SubscriberHello everyone
I want to find stiffness matrix of a finite element model using ansys. Is it possible? -
August 26, 2018 at 12:47 pm
August 27, 2018 at 1:39 pm
engmost
SubscriberThanks rohith
I cant access the link you suggested from ansys help.
Would you send a pdf file to my mail?
Hasanian.mo1991@google.com
Thanks in advance -
August 27, 2018 at 2:23 pm
SubscriberRohith,
I also can't access the help file using the link. It takes me to the customer portal login.
Students can't get an account on the portal. Fortunately, ANSYS 19.1 Help logs them in somehow.
Here is the URL after starting Help for Workbench 19.1
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v191/wb2_help/wb2_help.html
Here is the URL from your link:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v191/ans_apdl/apdl_math.html?q=math%20apdl
It looks like clicking on your link should work, but it doesn't.
What does work is to RMB on the link and select Copy Link Address, then go to the browser window that activating Help from the ANSYS Workbench 19.1 opened, and paste in the address, then you get to the required page.
This seems to be a common problem, so I posted a separate discussion with the clear instructions.
September 25, 2018 at 11:51 am
Rohith Patchigolla
Ansys EmployeeHi Peter,
Thanks for the clarification.
Best regards,
Rohith
August 30, 2019 at 1:56 am
tm426
SubscriberHi, I am not sure about that.
Hi, Could you let me know how can I access to ANSYS Online Help?
Best Regards.
August 30, 2019 at 3:51 am
April 21, 2020 at 5:08 pm
mingxuan
SubscriberHi, I have some problem in ANSYS Online Help.
I follow the step (1. From ANSYS Workbench, use the menu Help > ANSYS Workbench Help. A browser window will open.
2. In the post that has a link to the ANSYS Online Help, Right Mouse Button on the link and select Copy Link Address,
3. Go to the browser window that opened in step 1 and Paste in the address bar and you get to the required page.)
But the browser window opening is just like below.
And it still remain the same like below after I paste the address in the address bar .
Is there any problem needed to be corrected?
Best Regards.
April 23, 2020 at 11:13 pm
Aniket
Ansys EmployeeHi mingxuan Thanks for bringing this to our notice, but it seems to work for me with the exact same process and the link:
The only one thing I would I ask you to change is to keep the original window open and paste the link in a new tab instead of pasting it in the same tab.
peteroznewman, can you please check if the process is still working?
-Aniket
2120
1347
1118
461
