Stiffness of the weak spring
    • steveg21
      Hello:
      We all know that adding the weak spring can prevent the instability of the model. I know the unbalanced force that the weak spring can take could be neglectable but I think it should have a certain range. So I'm wondering how much unbalanced force can the weak spring takes? In other words, what is the default stiffness of the weak spring? Thank you.
    • sathya
      Hi You can check the same in solution information for default setting.By entering the values manually,you can specify desired stiffness.
      Ideally you should avoid playing with this setting.
