April 6, 2022 at 11:21 am
andechandra
SubscriberApril 7, 2022 at 3:54 pmAshish Khemka
It looks that the second layer from the bottom is giving trouble with meshing. Can you try clearing the generated data and then remeshing that part first? Also, along with error messages you will find some suggestions. Please see if they help.
Regards Ashish Khemka
April 12, 2022 at 10:29 amandechandra
SubscriberThanks you i will go through it
Trending discussions- How to work with STL file?
- section plane
- material properties
- Geometry scaling
- Coordinates orientation
5242
3287
2467
