September 5, 2019 at 6:56 am
viechr78
SubscriberHello,
is there any way to export a shell mesh to an stl-file in Workbench 19.2; now that the FE-Modeler is no longer part of it?
Up to now I used the FE-Modeler to export shell meshes to stl-files, but now I can't find any possibility to export them...
BR, Christiain
September 5, 2019 at 9:46 am
Ansys EmployeeCan you export from Mechanical?
September 5, 2019 at 9:53 am
viechr78
SubscriberThanks, that's working!
Is there a reason why the export works in Mechanical Model but not in a single Mesh-component?
- check element type
- How to resolve Mesh Failure
- Meshing Error
- Error in meshing
2524
2066
1285
1096
459
