Preprocessing
Preprocessing
STL exported file is broken
    • Ramy12
      Hello and thanks in advance,
      I’m not sure this even belongs here.
      I have trouble with a STL I exported Static Structural Analyses. If I export from a result which includes all bodies, I can open the file in a CAD-Program, but that’s not the case if I export only single-body-STL’s. The export itself works, but the file can not be imported in to another software.
      I know it should work because I did it like this bevor, but somehow that’s no longer the case.
      Does someone know what is causing this and how to chance it?
      Thanks for your help!
    • peteroznewman
      Please attach examples of single-body STL files that don't import, as well as examples of all bodies STL files that do import. Put these STL files inside a ZIP file. You can attach the ZIP file to your reply and say what version of ANSYS you are using.
    • Ramy12
      The export didn't work properly. The file of the separate bodies is unexpecteldy small.
      I'm using 2020 R1 (Academic Research and Teaching).
      Thanks for the help!
    • peteroznewman
      The small file is empty.
      I can open the large file in SpaceClaim. Then I use the Separate -All button on the Facets tab to break the single facet body into six bodies.
Viewing 3 reply threads
