3D Design
3D Design
.stl file face reduction issue
    • ah05085
      Hello all,nI'm having trouble reducing the faces on my .stl electric motor model. I've removed exterior faces from my rotor and stator so that now it looks like I only have about 30 faces but after using the measure tool it says I have 662 faces. This seems crazy so I'm think the faces are inside the model. I've also converted it to a solid.Should I upload my file?.Thanks in advance.n
    • peteroznewman
      Put your .stl file in a .zip file and attach that to your reply using the paperclip icon.n
    • ah05085
      I've already converted and saved it in spaceclaim. nn
    • peteroznewman
      What version of ANSYS are you using?n
    • peteroznewman
      Here is what you see in SpaceClaim.nIf you select each outer face and right click and select Face, Hide Face, you will find all the faces underneath.nn
Viewing 4 reply threads
