Preprocessing
Preprocessing
STL files pre-processing for CZM fracture
    • Li1003
      i am trying to do a cohesive zone method analysis to study interface delamination between 2 bodies which are generated from CT scan and available in stl format. I am trying to figure out a way to perform mesh with matched control between two contact surfaces so i would have idential mesh on both contact and target. The geometry looks like this
      Because it is from stl file, it is a solid with many facets. There are 766 faces on the contact faces. I was trying to merge them but i don't know how to select those faces in spaceclaim.
      Thanks in advance.
Viewing 0 reply threads
