Preprocessing
Preprocessing
STL to Parasolid
    • Abubakar
      Hi Karthik Sir,nCan you please tell me how to convert STL file into Parasolid (Solid geometry) in Spaceclaim?.Thank you,nAbubakar kha
    • System_delete
      This discussion was created from comments split from: 4 Equations and 13 Unknowns.
    • Karthik R
      Administrator
      nPlease open a new thread when you are asking a new question which is unrelated to ongoing discussion on any specific thread.nRegarding STL to parasolid conversion - you will first need to convert the STL into a solid geometry. Please see this thread.nAlso, you can use some reverse engineering tools. Please see some video tutorials here on these reverse engineering tools.nThank you.nKarthiknn
      As an aside, depending on what you plan on doing with the stl it may be easier to clean up the surface and use Fluent Meshing. Unless you need to for other reasons you may not need to go through the conversion process. n
Viewing 3 reply threads
