August 9, 2018 at 7:06 pm
dray19
SubscriberHello,
I am looking at the fluid dynamics in a square microchannel for 0.1<=Re<=1000. This involves determining the hydrodynamic entrance length and the friction factor for both the developing and developed regions.
I have conducted a mesh independent study for several Re>100 and validated the results with previous researchers experimental and analytical work
When I did the mesh independent study (7 meshes) for Re=0.1,1,10, inlet pressure increases by 2% (~0.01, 0.1, 1 Pa respectively) with each mesh refinement. The other parameters (velocity, entrance length) seem to constant expect entrance length changed in last few meshes. I increased the number of elements in each direction by 25% to give approximately 2x the number of elements.
Should I keep increasing the mesh? Am I missing something else? I have read (forums) that fluent should be able to handle creep flow but maybe it can't.
Any help is greatly appreciated.
Attached are the results for Re=0.1 mesh study
Model Information:
Microchannel: 100um x 100um x 210um
Model Domain: 50um x 50um x 210um (symmetry applied)
CFD: Ansys Fluent 19.1
Double Precision
Solver - Pressure-Based, Steady State
Model – Laminar
Residual – 10E-6: Continuity, Velocity in X,Y,Z Direction
Methods:
Scheme: SIMPLE
Spatial Discretization
Gradient: Least Squares Cell Based
Pressure: Second Order
Momentum: Second Order Upwind
August 9, 2018 at 8:36 pm
Raef.Kobeissi
Subscriberhi,
how did the pressure inlet increase by 2% ? This is a boundary condition and should remain constant regardless of the mesh, can you send a picture that shows this increase.
Regards
August 9, 2018 at 9:26 pm
Karthik R
AdministratorHello,
Could you please elaborate your meshing strategy near the wall? How is your boundary layer mesh? How does it change with each successive refinement?
Thank you.
Best Regards,
Karthik
August 9, 2018 at 9:39 pm
dray19
SubscriberRaef,
I am using a Velocity-Inlet and Pressure-Outlet boundary conditions. If I apply a Pressure-Inlet B.C, the velocity profile is fully developed at the inlet and I can't determine entrance length or developing friction factor.
August 9, 2018 at 9:54 pm
dray19
SubscriberKremella,
I set the number of elements for each direction (ex: 15 in x, 15 in y, 65 in z-axial direction) and apply a bias factor to have smaller elements at the walls and in the developing flow regime. For refining, I increased the number of elements in each direction by 25%
August 9, 2018 at 10:08 pm
Karthik R
AdministratorHello,
Please take a look at this discussion on the student community. This might help you understand mesh independence better.
https://forum.ansys.com/forums/topic/convergence-of-results-in-the-study-of-mesh-independence/
Thank you.
Best Regards,
Karthik
2524
2066
1279
1096
459
