Stop Imposed on a Revolute Joint
    • kdh195
      Joint - Rotational Velocity at two holes.
      and I imposed Stop.
      Then an error has occurred. : Stop on Joint Revolute - AB is violated in direction RZ by -0.8184... - Check your model for ill-conditioning and large difference between applied forces and inertia forces.
      What can i do for this error ?
      Thank you !
    • peteroznewman
      You can't have both a rotational velocity that must always be present, and a revolute stop that prevents motion.
      Replace the rotational velocity with a torque and keep the stop. There is no inconsistency in this combination.
