LS Dyna
LS Dyna
Topics relate to LS-DYNA, Autodyn, Explicit STR and more
Stop lsopt manually with a command in terminal window
    • Deepak Kumar
      Is it possible to stop lsopt run with a command in the terminal ?
      I want to integrate it into my python script for termination criteria.
      Thanks in advance.
    • Imtiaz Gandikota
      You have to first stop/kill the ls-dyna/solver jobs submitted by ls-opt job scheduler. Please check appendix on killing jobs in ls-opt user's manual. You can send kill signals to each solver job or the entire job scheduler. A sample command to stop job scheduler is,
      /path/LSOPT_EXE/lscheduler ctrl stop
