August 12, 2022 at 7:01 pm
jmoss
SubscriberHow do I stop a transient simulation once a certain condition is met? ex: Inlet pressure has reached a target value.
Thanks in advance!
August 15, 2022 at 1:33 pm
RK
Ansys EmployeeHello,
You could use the execute commands to set the conditions. Please see the users guide.
August 23, 2022 at 1:28 pm
jmoss
SubscriberThe command shown below isn't working. I want the calculation to stop once the inlet pressure decays below 0 bar at the inlet.
Is this the correct way to write the command? (Inlet zone ID = 6)
(if ( < 0 (pick-a-real "/rep/volume/volume-avg 6 , pressure n")) (set! mstop? #t))
Users guide does not explain how to write scheme programming.
Thanks for your help!
August 24, 2022 at 2:37 pm
Ansys EmployeeI don't think there is any public Scheme documentation. My approach is to monitor the value of interest and manually stop the model once that point is reached. Otherwise you need a monitor linked to a trigger to cause the convergence criterion to be met.
5364
3363
2471
1310
1018
