Strain and Temperature data not stored in result file
    • carpekev
      I am running simulations in ANSYS Workbench (coupled fields), and am using APDL commands to activate elements and apply heat fluxes at different time steps. Once the simulation finishes, I try to generate the Temperature and Strain solutions, but an error message says that these data are not stored in the result file. Is there a command that I need to include in the APDL code to save these data?
Viewing 0 reply threads
