Materials
Materials
Strain Life Parameter
    • Kiana Dullas
      Hello, I'm working on research about Reinforced Concrete Column that will be tested under fatigue test but an error occured says missing Stress life curve. Does any know the strain life parameters of concrete?
    • Ashish Khemka
      Hi Kiana,
      This error message ' Invalid or missing stress life curve.' may be issued if the material you use does not have an SN curve. Please see if the following link is of help to you:
      https://www.researchgate.net/publication/313884920_Fatigue_Properties_of_Plain_Concrete_under_Triaxial_Tension-Compression-Compression_Cyclic_Loading
      Ashish Khemka
