Strain rate dependent material model for Transient Structural analysis.
    • HiwaGhaffari
      Hi.
      Is it possible to define strain rate dependent material models (for example Johnson-Cook model) for a Transient Structural analysis? I want to analyse a sheet metal forming process with initial stress, which should be imported from a csv file (so I cannot use an Explicit Dynamics system) and the material should be modeled using Johnson-Cook model or another strain rate dependent model.
      Can anyone please help me?
    • Soni
      were you able to find a solution to your problem ?, I am facing the same issue and if you could help me with whatever you know, I would be very thankfulnwarm regards,nSonin
    • HiwaGaffari
      Hi. No yet, and I think there is no way. Maybe I will have to do it in Abaqus if possible. n
