Strain-Stress Plot from Deformations of Beam elements
    • Mik
      Goodmorning, I'm a student in training with ansys so maybe I'm asking a very stupid question.
      I'm working with Lattice Structures, in particular an Octet-Truss structure, as shown in the figure. I will try to list the workflow to let you understand better:
      -I built the structure with a CAD and saved it in STEP file.
      -Then I uploaded the step file in Geometry->SpaceClaim and used the command "Extract Beams", because I'm supposed to work with beam elements. Then I closed every node and that's it, I obtained the same structure but made of beams and closed nodes.
      -Then I went to do a Modal Analysys and it worked fine. So I opened a "Static Structural" analysis and went to "Model".
      -I then went to set the mesh grid to 0,5mm, then 4 bottom fixed nodes, another 4 nodes (top) fixed in rotation and displacement and then I applied a nodal force of 1000N on the top 5 nodes.
      Now, the thing is that it seems I can only solve for "Deformation" or Axial/Shear ((and it's totally understandable)) but the final goal were to find a strain-stress curves (i already have the properties of the materials).
      So I'm asking if there's a way to obtain the strain-stress curves of this sctucture directly from Ansys and from the deformations results of this simulation even if it's a "Beam Structure" OR If I have to do another separate simulation with the "Normal Strucutre".
      I hope i've explained myself well, sorry for the long post and the bad english.
      Mik
    • Mik
      Goodmorning, I'm a student in training with ansys so maybe I'm asking a very stupid question.I'm working with Lattice Structures, in particular an Octet-Truss structure, as shown in the figure. I will try to list the workflow to let you understand better:-I built the structure with a CAD and saved it in STEP file.-Then I uploaded the step file in Geometry->SpaceClaim and used the command "Extract Beams", because I'm supposed to work with beam elements. Then I closed every node and that's it, I obtained the same structure but made of beams and closed nodes.-Then I went to do a Modal Analysys and it worked fine. So I opened a "Static Structural" analysis and went to "Model".-I then went to set the mesh grid to 0,5mm, then 4 bottom fixed nodes, another 4 nodes (top) fixed in rotation and displacement and then I applied a nodal force of 1000N on the top 5 nodes.Now, the thing is that it seems I can only solve for "Deformation" or Axial/Shear ((and it's totally understandable)) but the final goal were to find a strain-stress curves (i already have the properties of the materials).So I'm asking if there's a way to obtain the strain-stress curves of this sctucture directly from Ansys and from the deformations results of this simulation even if it's a "Beam Structure" OR If I have to do another separate simulation with the "Normal Strucutre".I hope i've explained myself well, sorry for the long post and the bad english.Regards, Mikhttps://us.v-cdn.net/6032193/uploads/FAXVD0GW4RBF/test.pnghttps://forum.ansys.com/discussion/22233/strain-stress-plot-from-deformations-of-beam-elements
      I wanted to add that I see beams like in the figure below AND under the 'Solution' panel i cannot select either Stress or Strain calculation... Both commands are greynArrayn
    • Ashish Khemka
      Forum Moderator
      nnYou can extract the stress and strain result at a vertex and then use the Chart to plot the stress-strain graph. Please see following link on using the charts:nnRegards,nAshish Khemkan
    • peteroznewman
      nInsert a Beam Tool into the Solution branch of Mechanical Outline.nInsert one of the Stress components under the Beam Tool: Direct Stress (axial), Maximum Bending Stress or Maximum Combined Stress (axial plus bending).nRead the online help for more information. Beam Tool (ansys.com)n
Viewing 3 reply threads
