October 1, 2018 at 11:12 pm
DoubleCNg
SubscriberHello guys,
I have encountered a strange deformation for my wind turbine blade during a simple tensile test on it. I applied 7700N tension on Z direction and it bended instead of elongated as it should be. Do you guys have any idea what is happening? Please note that it is a [+-45]4s composite with 0.229mm each layer (3.664mm in total), and the length is 25 meter. I imported the shell element from ACP(Pre), it is still the same even if I imported solid element. The solid model is created by using SOLIDWORKS.
And also, does anyone knows under what condition should the shell element or solid element be used?
Chu Chiat Ng
October 2, 2018 at 12:30 am
SubscriberHello Chu Chait Ng,
If you plot at true scale, is the deformation in the Y direction still visible?
Peter -
October 2, 2018 at 12:38 am
DoubleCNg
SubscriberHi peteroznewman Thank you for reply. I'm quite new to ANSYS workbench, may I ask how to plot the result at true scale?
Regards Chu -
October 2, 2018 at 12:53 am
October 2, 2018 at 10:53 pm
DoubleCNg
SubscriberHi SandeepMedikonda Thank you so much. The deformation is finally become normal.
Regards Chu
2068
1289
1106
459
