Strange results : static pressure higher than total pressure
    • Quentin Lambert
      Hi !
      I study the fluid sloshing on a cylindrical tank composed by water (radius 10m, height 12.5m, height of fluid surface 5m).
      I use a sampleprofile transient as a translational velocity on my fluid on the X direction to simulation a seism.
      I want to export the total pressure on my tank, however on CFD-post, the static pressure is higher than the total pressure...
      Thanks for your help !
    • Keyur Kanade
      Please check if you are using local or global range.
      Also please calculate it using calculators --> function calculator and then compare.
      Keyur
    • Quentin Lambert
      Hi Keyur !
      Thanks for you help but my static pressure is always higher in local range.
      Regards
    • Raef.Kobeissi
      hello,
      can you please upload your case file and I will have a look at it.
      Regards
    • DrAmine
      Static pressure cannot be bigger total pressure as it is the sum of dynamic head and static pressure head (gauge+reference pressure). Please check your post-processing and attach some screenshots.
      Cheers and kind regards,
      Amine
    • Quentin Lambert
      Hi !  Thanks for your reactions !
      My post-processing comes down to watch the total pressure in CFD-Post without using any udf.
      I let you some screenshots in attachment.
      Regards
    • DrAmine
      Can you please check it in Fluent directly and tell me which pressure interpolation are you using?
      Best regards,
      A.
    • Quentin Lambert
      Hi !
      I use the Body Force Weighted.
      Best regards.
    • DrAmine
      What about the pressure contours in Fluent?
      A.
    • Quentin Lambert
      Hi !
      It's exactly the same.
      Best Regards
    • Raef.Kobeissi
      I checked your pictures and as abenhadj said, the static pressure cannot be higher than the total pressure. What you're plotting there is the hydrostatic pressure in a tank ( I assume) and it does look equal to total pressure (the contour might show higher top value) but I bet that the Pressure total is not higher than the hydrostatic pressure.
Viewing 10 reply threads
