May 2, 2022 at 2:45 pm
May 2, 2022 at 4:25 pm
Devendra Badgujar
Ansys EmployeeHi Healme
Please can you share your model so that I can check on my end to understand it better.
Regards.
May 5, 2022 at 7:18 am
hilmar.meienberg
Subscriber🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Devendra Badgujar
Probably not worth discussing further here as it is neither a bug nor important. Iterations over 100 are just not displayed in a meaningful way. You can check this with the attached model. Open the details of the mass plot and look at the iteration axis. Since the axis shows at most 5 values, this effect occurs. Furthermore, there are rarely topology optimizations with more than 100 iterations where the mass still changes significantly.
May 5, 2022 at 7:33 am
Devendra Badgujar
Ansys EmployeeHealme
Thanks for your update. I will check and will let you know if I have any more information on this.
Regards.
May 23, 2022 at 8:59 am
Devendra Badgujar
Ansys Employee🛈 This post originally contained file attachments which have been removed in compliance with the updated Ansys Learning Forum Terms & Conditions
Hi Healme
I was not not able to reproduce this behavior at my end in Discovery 2022 R1 version. Please check the attached image.
Regards.
May 23, 2022 at 9:57 am
hilmar.meienberg
SubscriberDevendra Badgujar Thank you for the cross check. After 100 iterations you won't know, is it 101 or 109 iterations, the graph shows only steps of ten. Is there another display that accurately shows the number of iterations over 100?
May 23, 2022 at 10:59 am
3862
2629
1859
1252
600
