Preprocessing
Preprocessing
Stratified wall shear on a circular cylinder
    • AllenXing
      Dear all,
      Does anyone know the reason of the stratified wall shear stress on a circular cylinder as shown in the picture? The wall shear stress should be continuous on the cylinder surface. I used turbulence model of k-w SST and created mesh from ICEM in ANSYS. Thanks!
      Best regards
      Allen
    • Karthik R
      Administrator
      Could you please embed your screenshot directly in your post? We are not able to download attachments from the community.
      Thanks.
      Karthik
    • DrAmine
      Might be related to mesh-to-surface projection in ICEM:
      already test what happens when either Settings>Meshing Options>Hexa Meshing>Project to bisplines is enabled or a tighter (e.g. 1e-5/1e-6) value for Settings>Model>Triangulation Tolerance has been set?
