Streamline rendering animation gets stuck everytime
    • AsifsoAwesome
      I'm using Ansys 20.1.Whenever,I try to animate streamline it gets stuck after couple of seconds and the cursor shows 'loading' sign as shown in the picture.Moreover,the app doesn't even close when stuck as a result,I have to end task from task manager.I tried decreasing the # of lines & also the quality of the animation but result is the same.Would be grateful if anyone could provide a solution.
      How much RAM/cpu is available when this happens?
    • Keyur Kanade
      are you able to plot contours?
      can you please change properties of streamline?
      can you please check if you can draw pathlines in Fluent?
      Keyur
    • Keyur Kanade
      Moving this to result visualization category.
    • AsifsoAwesome
      around  53% of RAM and 33% CPU  is used at that time when process going on.
    • AsifsoAwesome
      Yes I can plot contours and tried again after changing the properties,but it is the same.
    • AsifsoAwesome
      I've uninstalled 20 R1 and installed 19 R2,now it works fine.Thank you
    • Keyur Kanade
      good that it worked. we will try to reproduce it at our end to check it.
      As it solved, can you please mark this post as 'Is Solution' to help others on the forum.
      Keyur
Viewing 7 reply threads
