May 25, 2018 at 7:01 am
hrebohm
SubscriberI found streamlines crossing walls and particles following this streamlines crossing the obstacle too. I assume the underlying grid is to coarse in relation to the size of the obstacle. That means the user must get an Information of grid size to use the code correctly. Please give me a hint how to avoid this situation. -
May 25, 2018 at 9:57 am
Subashni Ravichandran
Ansys EmployeeHi @hrebohm If the obstacle is too small compared to the entire geometry under consideration, Discovery Live tends to ignore them. You may try running it again with maximum fidelity to get a more accurate result. Also, I would suggest you refer to Discovery Live: "Thin" geometric features and relative GPU adjustments for a better idea of how to work thin geometries. -
May 25, 2018 at 10:39 am
hrebohm
SubscriberThanks for the answer, but an information of grid size would be helpfull to avoid problems with thin geometries, because "thin" is defined in relation to grid size.
May 25, 2018 at 11:09 am
Naresh Patre
Ansys Employeehrebohm The information on grid size is currently not available. It is important to note that because Discovery Live is designed to provide an interactive workflow for a wide range of supported graphics cards, it adjusts the available fidelity range (minimum and maximum) to keep a fine balance between performance and level of detail. This means that depending on the available graphics memory and computational resources, the limit on what Discovery Live is able to resolve geometrically changes.
May 25, 2018 at 6:45 pm
andrew.in.sheffield
SubscriberSince the grid is so dependent on hardware a graphical representation of the grid size relative to fidelity settings for given hardware would be very useful to the user to in order to identify which features will be captured.
May 28, 2018 at 4:24 am
Naresh Patre
Ansys EmployeeHello ahobbs We thank you for sharing your feedback. We will share your idea/input with the product development team.
- Copy user settings to new release
- Electric Heating – Ansys AIM
- problem to access on the spaceclaim help
- Discovery Getting Crashed
- Dwg export error
- Critical error
- BUG to correct is important
- Error messages running solver
- Discovery Live freezes with multiple load cases while topology optimization
- Unexpected graphics error
3632
2502
1729
1222
578
