July 24, 2018 at 2:18 pm
ewold
SubscriberHello,
I have a pipe that is being translated in space back and forth with fluid moving inside of it. When I try to visualize the velocity streamlines of the fluid, Fluent shows me streamlines that correspond to the velocity of the pipe, not the fluid inside the pipe. How can I see the streamlines of the fluid with respect to the pipe, even though the velocity vector is dominated by the overall movement of the pipe?
Thanks
July 24, 2018 at 9:22 pm
Karthik R
AdministratorHi,
Check out the 'Reference zone' from the 'Reference Values' set-up options (section 32.12.2., Fluent Users Guide). Selecting the desired reference zone will allow you to plot relative quantities. Also go through section 9.3.6. - Postprocessing for MRF and Mixing Plane Problem. Here is a snip.
I hope this answers your question.
Best Regards,
Karthik
2656
2120
1345
1118
461
