March 22, 2021 at 10:44 am
Musiek17
SubscriberHello I model using Ansys Mechanical. I made a transient simulation simulation and obtained satisfactory results. I would like to write a structural one using the thermal results from the previous simulation but I have a problem. If the material above the temperature of the higher temperature, the stress should be 0, but I have a very high stress value. The maximum stress that I can obtain for this material is up to 220 MPa (Aluminum alloy 6060). I am sending you a photo of my results.
March 22, 2021 at 1:00 pm1shan
Ansys EmployeeHello Array,nnSorry, but I am not clear on what issue you are facing. I would like to write a structural one using the thermal results from the previous simulation but I have a problem - Do you want to couple the thermal results to the structural analysis? Could you please be more clear on If the material above the temperature of the higher temperature, the stress should be 0, but I have a very high stress value.nnRegards,nIshan.nMarch 22, 2021 at 1:05 pmMusiek17
SubscriberIf the temperature in the weld is above the melting point, the material is in a liquid state, i.e. it must not have any stressesnnViewing 2 reply threads- You must be logged in to reply to this topic.
2524
2066
1279
1096
457
