March 24, 2023 at 1:26 pm
eLeN_93
SubscriberI am trying to model a stress analysis on a one-supported cantilever beam (50x50 um^2 and thickness 200nm) that after the load is applied, comes in contact with the substrate creating an s-shape deformation. I have created my geometry and my model properly and I managed to create the load as well in order to have this shape by adding a variable load that follows a deflection function. My issue is that, although I define my fixed supports and my contacts in the model, after the analysis the cantilever ''ignores'' the contact constraint and penetrates the substrate. I have tried all the different types of contacts and that is the case. I also found in some supporting forums online that you can increase the stiffness of the substrate to avoid that, but still. Does anyone know how can I fix that?
Thank you in advance
March 27, 2023 at 11:24 am
Vinayak Vipradas
Ansys EmployeeHi,
Are you using the Default, ie Program Controlled Contact settings?
Vinayak Vipradas
3363
2471
1310
1018
