stress analysis of DC motor
    • swa123
      Hello
      I am quite new to the field of stress analysis of DC motors.I must give RPM & TORQUE as my input parameters to know about equivalent stresses and deformation
      When it comes to DC motor analysis I do not know where to start
      Please let me know what kind of analysis must be carried for the required input parameters
      Any kind of response will be helpful
      Regards
      Swathi
    • peteroznewman
      What would you do with the stress information if you had it?
    • swa123
       we would like to know how does the motor structure behave for the give load and rpm
      So based on the stress and strain that is acting,we would like to alter the design of the motor components for its best structural stability
    • peteroznewman
      Do you care about stress or deformation? It sounds like you care about deformation.
      Please show the critical location that you most want to reduce the deformation of.  Show where the housing is fixed to ground. Do you care about steady state deformation or also vibration?  Torque will affect steady-state deformation but RPM will have no effect on steady-state deformation.  Only if the rotor is unbalanced will RPM affect deformation, but that will be in the form of vibration, which is periodic motion.
      Use the insert image button to put the images into the post.
Viewing 3 reply threads
