Stress Linearization in Shell Bodies
    • hari123
      How to perform stress linearization in shell body ANSYS V19.0. (When I select above mid surface node, It's by default selecting mid node, same in bottom)n
    • Daniel Shaw
      You can linearize along a multiple shell elements, but you cannot linearize through the thickness of a shell element. The results on the top and bottom of the shell element are essentially the linearized results.nn
